So my first post, yay! And I really hope this is in the right section. I saw other posts about pumps so fingers crossed.
We’ve had our pool for two years now, and after two weeks of vacation wanted to use the pool.The pump wasn’t running while we were out because it’s been 100 degrees here and we didn’t want to risk it evaporation off and running the pump dry. After cleaning it all I went to pour in chlorine and turn the pump on but it doesn’t even attempt to turn.
yes, it is plugged in as the lights are on. I’ve checked and ran water out of all the lines via disconnect. The motor doesn’t even attempt to run water, nor can you hear or see any water moving through the unit.
any ideas?
any ideas?
