For those of you that have lived in Southern California know, we get yearly high winds around this time of the year. Usually, it means some leaves in the pool and a lot of dirt at the bottom of the pool. Usually, I let the pool cleaner do its work and then I clean the filters. I can always tell when the filters are gunked up because the cleaner starts to move slowly and the waterfall off the spa slows down.
Well, I let the winds to their thing and then get the filter moving after skimming out all the leaves. This time though it doesn't even start to clean the bottom before it slows down. I open up the filter and clean it out today. Not terribly dirty as I was expecting, but enough that it needed a good cleaning. Clean out the skimmer and the pump pre-filters and turn it back on expecting it to be back to normal. Nope. Still barely moving water and the cleaner is crawling slowly. Check the filters and the pressure is at 5 bar, not above 20 bar as it's supposed to be. Turn on the spa and it only hits 12 bar. So something isn't working right and I'm not sure what. Any guesses on what to check next? I got a pool full of dirt and I need to get it cleaned!
