Pump motor mount bolt flange cracked? (picture)
pool123455
4
Los Angeles, CA
New to pool maintenance and working through all the pieces of the system. I have a Pentair WhisperFlo WFE-3 pump with an A.O. Smith QC1102 motor. Noticed the housing gasket has a small leak at system power-on, so am planning to replace that seal and check the other components as well as motor bearings.
In preparing for removing the motor from the mounting plate, I discovered that both of the lower motor mount flange corners (where the bolts hold the motor to the plate) are half-missing (the dark grey in the image). It seems to be holding fine right now, but I'm wondering about re-securing it once removed. What options do I have?
Jimrahbe
15,002
Bedford, TX
55,
I would use this as an opportunity to buy a new IntelliFlo VS pump and save on the old electrical bill.. :mrgreen:
I'm sure James will provide some real advice, but if this were my pump, I would proably add a larger washer under each bolt and use it as is..
Reactions: Chuckiechan
JamesW
16,727
I suspect that you're going to have other problems taking this apart.
Probably going to need a seal plate and impeller.
I would replace it with a intelliflo.
What are your electricity rates?
Reactions: pool123455
pool123455
4
Los Angeles, CA
Thanks for the replies so far. Electric rates are about $0.173/kWh in Los Angeles area. I have solar so my worst months (winter) are still less than 250 kWh/month net usage, while spring/summer gets as low as 50 kWh/month net.
I'm not sure if a $1k+ new pump is the preferred option right now.
JamesW
16,727
How old is the pump?
How loud is it?
I think that replacing it is probably going to be the best choice.
I think that it will be obvious in retrospect if you decide to go the rebuild route.
Maybe get a Superflo VS.
