Pump making strange sound
jkayca
76
Ottawa Ontario
I'm hoping someone can help me with a strange sound coming from my pool pump. Rather than trying to describe the sound, I've got a short video New video by Jeremy Kalman
This happened when opening the pool and starting the pump for the first time this season. Water is moving. No leaks either. I did pull the pump off the basket to inspect the impeller but couldn't see anything obviously wrong with it.
At first I though maybe the starter cap. but the thing is actually running.
It's a Hayward Super II series pump, about 10 years old.
Thanks.
duraleigh
Admin
Platinum Supporter
In The Industry
Apr 1, 2007
32,901
Bearings.......pretty sure.
On another subject, you also likely have a suction side air leak. Fix or replace your pump first but then you need to find that leak
Reactions: splashpad
jkayca
76
Ottawa Ontario
Man, just looked at a video on how to replace the bearings. Don't have the tools, skill or the patience so looks like a new pump.
Also, why do you think I have a suction side air leak?
duraleigh
Admin
Platinum Supporter
In The Industry
Apr 1, 2007
32,901
I suspect Dave mentioned that because of the amount of air in the basket churning around
That's correct. A circulatory system that has NO leaks will have NO air in the pump basket. It may be tough to find but it is important to find it.
jkayca
76
Ottawa Ontario
Thanks for the advice folks. I think the churning is due to the fact I just opened the pool and there is still air in the lines. Due to the racket the pump is making I haven't run it long enough to get it all clear.
Anyway, I will replace the motor and keep an eye on it.
Thanks.
jkayca
76
Ottawa Ontario
So got my new pump and I got a seal kit with it. Unbeknownst to me, I didn't realize you're not supposed to touch the white ceramic part of the shaft seal. Well I touched, my 12 year old son touch it. Can I still use it? Can it be cleaned? Not entirely sure why touching it is a problem.
Thanks
jkayca
76
Ottawa Ontario
Thanks! Wiped it clean with some paper towel then doused it with the alcohol. Let it air dry for about 20 minutes and then finished the install.
Pump is much quieter and moving water well. I do have a minor leak on the output. Something to deal with on the weekend. I also still seeing some turbulence in the basket area. I also tackle that on the weekend. I also noticed the white hard plastic gasket (?) on the front of the impeller diffuser was worn and asymmetrically at that. I'll probably need to replace that at some point to.
Keeping an eye on things for now. Thanks for all the help.
