Going to try and be as thorough with the info, so we don't go down the rabbit hole of Pump Lid seals, suction leaks etc.
Variable Speed Pump
Sand Filter with Hayward Multiport
Two main Drains into one intake line (valved), One Skimmer in other intake (valved)
Three Returns in three separate lines (two inground in one valved line, three fountains in one valved line , six jets in one valved line)
Symptoms:
Pump loses prime on Filter position ONLY. No loss of prime or bubbles on Circulation, Backwash, or Waste.
Actions and Info:
Changing from Main Drain to Skimmer to Both makes no difference. Water level in Pool is fine.
Changing Pump Lid Seal makes no difference (no air in other modes). Greased and New.
Rebuilt Pump Seals and Changed Impeller, no difference.
Swapping between fountain, main returns or jets, makes no difference on returns....These are three separate pipes, so not likely any kind of underground leak
No water loss in pool
No dirt in pool
At 1800 RPM Pump PSI is about 12. At 2400 RPM it is around 18. At 3200 RPM it is around 30. Normal operating range is 1800 RPM.
Have backwashed filter multiple times. Pressure drops a few PSI but nothing major.
Have done deep clean of Sand Filter multiple times.
Have changed Filter Sand.
Have changed laterals.
None of the above resolves the issue....Pump loses prime in about 4 hours. Only way I can run is to program multiple timers which on the Vari-pump starts a Prime at 3400 RPM. But even that doesn't fill the basket, only raises the pressure and partially refills pump basket.
Everything to me points to a blocked filter, so the last thing I have to change I suppose is the multiport valve. Would seem odd that only the Filter port would be blocked and none of the others, but maybe? Since both backwash and filter uses the stand pipe, I don't think it could be full of sand causing an issue? Especially since backwash goes down the pipe and out the laterals? I would think that would be harder to push through.
I'm at my wits end on this one. I'm about to the point of emptying the filter of all sand and seeing what happens, or buying a new valve. Please help!
Variable Speed Pump
Symptoms:
Actions and Info:
No dirt in pool
