Pump hums, overloads circuits, impeller is turning
mglaman
5
Southeast WI
I went to go boot up the pump so we could open our pool. The pump gave off a hum for a few seconds and then overloaded the circuit breaker. Took it apart and the impeller was stuck, but after a while it began moving freely. I was able to get it spinning, so I thought I was in the clear.
Hooked everything back up. Sounds a bit stronger, but still – poof. Shorts the circuit. Is the problem the capacitor, probably? It looked okay, but I guess that doesn't mean much about the inside of it.
mglaman
5
Southeast WI
🤯the pump ran for a few hours, but I noticed it getting hot and that electric smell. Turned it off, and now it won't turn over again – just a lot of humming. Impeller turns just fine.
