Pump going out?
Texas Splash
Audible sounds like squealing or even heavy grinding are symptoms of the bearing beginning to wear. In some cases, you might find a local repair shop experienced to inspect such things or replace the bearings. Depending on the age of your pump/motor, it may simply be time to swap it out for a new one.
