Public Pool Test
arisal2k
50
Seattle, WA
Hi All
My kids do swim team at a public indoor pool. Been hearing horror stories of kids picking up chlorine pucks, cloudy water, bandaids, etc. Decided to test the water with the TF-100 kit:
FC 3 ppm
CC 1.5 ppm
CYA 100
CH 725
TA 90
What is the collective wisdom? Safe to swim?
My understanding of the TFP philosophy applied here:
1. Shut the pool down.
2. Drain the pool. At least 75% water should be replaced. Get CYA to 25.
3. Stop using pucks and powder shock. They are likely causing stratospheric CH and CYA levels
4. Liquid chlorine, SLAM the pool. Don't re-open until SLAM is complete.
  • Wow
Reactions: Mdragger88
mknauss
44,307
Laughlin, NV
Fiberglass
Pentair Intellichlor IC-40
Indoor pool with high CC needs its water exchanged. CH is not a health issue. Low FC to CYA levels is.
mknauss
44,307
Laughlin, NV
Fiberglass
Thanks for confirming. What's the appropriate level of concern or urgency here in your opinion?
Was the CYA exactly 100 or over 100? At that level of FC, you are on the precipice of person to person viral / bacteria transmission. I am surprised that the local health codes allow that much or in fact, any, CYA to be used. The CC will just be presented as itchy red eyes, stinky water, etc.
Reactions: KJB1
arisal2k
50
Seattle, WA
It was just about 100. The cya test is a little bit subjective.
mknauss
44,307
Laughlin, NV
Fiberglass
True. Use a 1:1 solution of pool water and tap water when the CYA is high. Then double the results.
Leebo
Admin
11,017
Eastern Ohio
arisal2k
50
Seattle, WA
arisal2k
50
Seattle, WA
Thanks for posting the Washington state standards. I've attached the relevant chemical levels with apparent violations highlighted in red. Time to escalate?
Mdragger88
3,131
Hernando, Ms
Intex Krystal Clear
I am surprised that they even have cya being as its an indoor pool. Many don’t.
Also surprised they don’t have a liquid chlorine dispensing system. Maybe it broke & they switched to pucks 🤷‍♀️
Sounds like ear infection central - among other things….
Leebo
Admin
11,017
Eastern Ohio
It’s clear the venue doesn’t care about the quality of the water just by looking at your results, forget the rumors…..just looking at facts I’d be worried. If it were I a strong hint to those who run the place should be given and there’s zero percent chance I’d let my children in that water. If the individual who maintains the water isn’t willing to listen I’d save my breath and just walk away taking my kids with me.
Reactions: Turbo1Ton
Leebo
Admin
11,017
Eastern Ohio
I also lied the more I thought about it…….
Instead of a discussion with the individual who maintains the water I’d have a discussion with the coach. It’s highly likely that you’ll have a better/closer relationship with the child’s coach than you will the maintenance guy, and the coach will likely have a better relationship with the maintenance guy. Explain to the coach your concerns and show them the violations, I suspect they’ll be upset too. If however they don’t wish to address things, then I’d put my child’s safety first and take a walk.
arisal2k
50
Seattle, WA
Update:
Numerous emails have been exchanged. Lots of excuses from the owner, who seemed to be offended that someone tested his pool water. Says they are gonna exchange the water on schedule in December. However, I fail to see how the CYA situation magically goes away between now and then. Coaches are appalled. Owner kinda blowing it off like no big deal, not addressing the problem, passing it off on the pool maintenance guy.
Will be contacting the health inspector ASAP. That was great advice and in hindsight should have done that straightaway.
TampaKathy
463
Tampa, FL
I think you did the right thing. You gave him a chance to fix it, he declined, now he'll have no choice. What made you test the pool water? Did you think something was wrong or were you just curious? I wish I had thought to do that on the 2 public pools I was swimming at...one I bet was fine, the other...questionable.
Leebo
Admin
11,017
Eastern Ohio
The huge majority of states require public pools to keep records of all testing for a certain number of years. They require testing to be done daily on certain parameters and the venues are required to record all results. These records are required to be shown to the health inspector if they request.
Drain/refills are nothing to public pools. Many use drains as a way to reset their chemistry to cover up their poor habits, just like this venue seems to be doing. Contacting the health department will likely result in some short term fixes, I doubt much will be done long term.
Since you’ve been able to get the coaches attention and I’d assume the coaches have a healthy relationship with the venue, I’d next suggest the coaches ask for a copy of the venues test results. They may not comply, but they may. If they do you’ll be able to see the long term trend and encourage the coach to take certain actions. If the quality of water mirrors the results you’re seeing now, encourage the coach to look for another venue. It sounds like they’d maybe listen to you. 👍
reggiehammond
373
Fort Worth, Texas
CircuPool RJ-60 Plus
Update:
Not surprising - no one wants to admit they're asleep at the wheel. Especially in regards to potential health issues...
Good luck with your county/city health department, they should take it seriously and get the owners' attention.
arisal2k
50
Seattle, WA
Thanks. No tolerance for an owner getting defensive about pool chemistry facts and making up excuses to justify why they are putting the unaware community at risk. The assertions of "not a big deal" and "not a safety issue" will now be in the hands of the health inspector to determine.
In the meanwhile, the swim team coaches have canceled practices for the week while they try to convince the owner to exchange the water. Otherwise, unless the owner shuts the pool down for maintenance it's still open for other community use.
I have since come to understand that
  • the main drain cover is broken and not securable (requires complete drain to fix)
  • the automatic chlorinator for the hot tub / spa has been broken for months. Someone comes every evening to shock it and they let levels fall during the day.
  • the ventilation system is broken, they literally have kickboards plugging up overhead ductwork
  • there is an external door that doesnt auto close and is not lockable
Maybe I should have named this thread Swimming Pool Nightmares and asked for help from Gordon Ramsay :sick::eek:
