Proper electric heat pump plumbing setup
Heisenberg328
5
Boston, MA - USA
Hello fellow TFP followers,
I recently purchased a Raypak 5450 Electric Heat pump for my 24' above-ground pool w/ 1HP Hayward Pump. I have an electrician doing the wiring, however, I'd like to attempt the plumbing myself; as I have a (seemingly) simple setup. Plus I assume hiring a plumber is a bit overkill for my setup.
Is this as simple as using the traditional 2" flexible hose w/ clamps for the cold input and hot output? Am I missing something?
Is this the correct setup? Water from Pool -> Pump -> DE Filter -> Heater -> Pool return
Any tips/advice is greatly appreciated.
Thanks!
Newdude
19,966
NY
Hey Heis and Welcome !!
The HP has traditional glued PVC unions. You will need to concoct an adapter from the one to the other. Bring the flex pipe and the Union to a plumbing supply store (Not HD/Lowe’s) and the the employee that knows plumbing (not just the ‘plumbing aisle’) will get you what you need.
Yup. (y)
