In the tail end of a pool reno and am curious as to how to set up my pump in terms of programming. Have a 32,000 gallon pool and a separate 800 gallon spa (that does empty into the pool) and the PB installed 2 X 3 HP Pentair Intelliflo VSF Variable Speed and Flow Pumps (one for the pool, one as a spa booster). Also have an Intellichlor IC40 salt cell that won’t be up and running for a month.
For the main pool pump, what kind of schedule should I be running? The PB did recommend ignoring setting things based on RPM’s, but to set the programs based on GPM (right now we have it set at 75 GPM when the heater is on or the spa is being used - translates into 2,700 RPM and 1,300 watts being used.
