I recently had my pool resurfaced using Stonescape Aqua Blue Mini pebbles. From day one, I had so many problems with the installer I don’t know where to begin. From the day they drained my pool to the day they finally started refilling it was 35 days. I was told 7 to 14. They finished the plaster work on a Saturday and didn’t return to acid wash and power wash until the following Tuesday. The manufacturer‘s website clearly states that 24 hours is the maximum time between finishing plaster and starting the refill so the finish doesn’t dry out. The end result is a shocking amount of excess plaster on top of the fact that the very limited areas with actual pebble exposure look nothing like the color I chose. My installer tells me that with a few weeks of brushing, the excess plaster will all miraculously be gone. Well after four days of spending 1.5 hours a day brushing 3 times (on top of balancing the water chemistry several times per day), not a shred of excess plaster has been removed. I am certain it’s because they didn’t expose the pebble properly on the day they plastered (they were done in less than 5 hours for a 14,000 gallon pool) and they let it dry for 3 days before acid washing and power washing. I’m so upset at how it looks. There aren’t two square feet that even have a uniform look. Thankfully I stopped payment on the 60% balance due check I wrote but I am very concerned that the surface can’t be remediated because of the poor installation. I’m very reluctant to drain the pool after five weeks of being empty so I am looking for any suggestions. I am a new pool owner so don’t know much about these pebble finishes. Thanks in advance.
I just added some pictures. You can see some areas where the surface is a little darker. That is where some of the pebbles have been exposed but significant plaster remains. The lighter areas are all excessive plaster with hardly any pebble exposure. My steps are almost smooth to the touch because they are basically plaster with some barely exposed pebbles mixed in. Thanks again for all comments. Hoping the manufacturer can assist.
