Problems with reagent R-0003
Snoufette
47
Cincinnati/ohio
I purchased a new bottle of R-0003 at the beginning of the season and the bottle is clear rather than yellow like my previous bottle and there is no change after adding my 5 drops to check for CC's. I contacted TF-test kits and (after much explaining of my issue) they sent out a replacement bottle saying that Taylor must have sent an expired bottle. However, the replacement bottle is no different. I have a few drops of my old bottle left so I know I have cc's. Anyone else have this issue or know how to rectify? I've reached out to them again in hope of a solution.
Snoobug
794
Iowa
My R-0003 bottle has clear liquid in it.
JamesW
27,679
Try testing your tap water.
Try testing distilled water for CC with the old reagent.
If you measure CCs in distilled water with your old reagent, then the reagent is bad.
Snoufette
47
Cincinnati/ohio
Perhaps the old bottle is the issue, not the new ones.
I’ve used this kit since 2013…. The five drops of r-0003 have always given me at least a minimal pink color that 1 drop of r-0871 would clear up, measuring .5 cc’s.
Can you have 0 cc’s with visible algae? That’s what I had with the bottle I asked them to replace.
JamesW
27,679
Plants, such as algae, create chemicals like glucose from carbon dioxide and water. Using light, the carbon in carbon dioxide oxidizes the oxide into oxygen.
6CO2 + 6H2O --> C6H12O6 + 6O2
Carbon dioxide + water--> glucose + oxygen.
This is how plants make oxygen and store energy in sugars. Most of the bulk of plants is carbon from carbon dioxide. Most of the weight of a tree comes from the air.
The carbon in carbon dioxide is in the +4 state.
The six carbon atoms in glucose are 4 atoms at an oxidation state of 0, 1 atom at at an oxidation state of -1 and 1 atom at at an oxidation state of +1.
The carbon is "reduced", which is the opposite of oxidized.
Reduced just means that the oxidation state is lower or reduced because the atom gained electrons which are negatively charged.
When chlorine oxidizes the carbon in glucose back to a +4 oxidation state, it reverts back to carbon dioxide.
This is a similar process to an animal using oxygen to burn sugars to release energy and exhale carbon dioxide.
So, chlorine reacting with algae is mostly an oxidation reaction and not a combination. Algae is mostly converted back into carbon dioxide and water.
Chlorine can combine with carbon compounds, such as methane (CH4) by replacing the hydrogen ions.
Carbon in methane is in the -4 oxidation state.
Algae mostly does not create CCs.
CCs are mostly created by compounds like ammonia where the nitrogen is in the -3 state.
For ammonia, you get combination and oxidation.
So, the CCs eventually go away, especially in sunlight where UV photons knock loose electrons from the nitrogen and make it easier for the chlorine to take them.
Active chlorine is +1, so it bonds with more negatively charged atoms, like nitrogen in the -3 state or carbon in the -4 state.
The carbon in algae has a zero net charge.
So, the reaction of chlorine with algae is mostly oxidation and not combination.
You can think of the sugar in algae as a type of fuel with calories that is ""burned" or oxidized to release the energy that was originally stored in the plant from the energy of sunlight.
