Pressure gauge orientation
bmccarthy98
1
Ashland, MA
Hi all,
I need a new pressure gauge as mine gets foggy and fills with water. I'd like to get this one: Pressure Gauge Glycerin filled 2.5" Bottom Mount but I'm wondering if it needs to be upright to work properly.
This is the way my current one is:
I'd like to keep it that way because if I put a rear mount one on it'll be facing the wrong way. I'd have to lean over the pump (there's a fence right next to it) to see it but it would still be tough to get head on for an accurate reading.
So, the question is: will that bottom mount glycerin gauge still work properly if it's sideways or does it need to be upright?
Thanks!
proavia
2,121
Chandler AZ
Upright would be best. You can add a short brass nipple and brass elbow so the gauge orientation is vertical.
