Pressure gauge connection repair
gbrenham
45
Cypress, TX
This just might not be possible now, but my pressure gauge stripped the internal threads of the filter. I don't want to (& couldn't afford) a new filter, so the only way I could fix it (before I found this forum) was to basically fill and glue it shut. I used liquid nails and a beer cap! That's some redneck stuff right there!!
Anyway, is there a way to undo what has been done and repair it correctly so that it will hold a pressure gauge again?
PoolGate
3,888
Damascus, MD
I wouldn't bother fixing it with a cartridge filter. My pressure never goes up at all I don't need it either. Not sure if you could fix it you'd probably have to tap the stripped hole for a larger size and then get an adapter for the gauge or find a gauge that fits the new size. Keep in mind if you did that you might compromise the filter housing which is a pressure vessel and probably not recommended.
Oh - You might be able to add a tap for a pressure gauge on the input PVC pipe going to the filter. Not sure if that is the same pressure as the filter while running I think it is.
Frank in FL
200
Florida
Id scrape out the liquid nails. Its not meant to get wet. What happens if you are away for a day or so and that thing decides to break loose? Use JB Weld "Water". Its designed to be used under water and would be ALOT better than the liquid nails.
