Preparing to build a pool/spa - Recommendations (Draft Plan Attached)
CHILINVLN
2
Chantilly, VA
I'm new the forum and starting to research existing threads. Previously, several years ago, I joined a forum before building a home theatre and the amount of information I learned to make the best decisions, paid off well! I'm hoping to learn the same about a pool.
I currently have a design draft, which is going through revisions. However, I will attach as a starting point. I've been steered towards salt water for less maintenance and I believe fiberglass would be the best option, with vinyl, and then concrete last. To be honest, I don't even know what questions to ask as I'm still absorbing so much information. If anyone has anything to share this early on, or links I should read, I'm very open to it. I believe my questions will quickly become more specific as I get a better understanding on things overall.
Texas Splash
For the pool/spa specifically, try to obtain as much details as you can about things like:
- Make/model of pump(s), HP, etc
- Type of chlorination and size of SWG if applicable
- FIlter make/model/size
- Plumbing size
- Accessories to the pool
- Type of vacuuming method
jblizzle
43,260
Noah382
17
Richmond, VA
I'm in Richmond and I'm going through the same thing right now as you, but I'm about to sign a contract. You can see my thread here that may help with some answers to some questions although seems like your budget is a lot more than mine: Fiberglass IG Pool Quote Review - Am I Crazy?
Semper Fi
CHILINVLN
2
Chantilly, VA
I appreciate the immediate feedback. I've jotted down notes on things to ask and questions to clarify.
Also, thanks to those complimenting the avatar. USMC Veteran here ending 2002, been involved in Government contracting since.
