Precautions when testing water
cme4oil
45
Phoenix Arizona
Hi,
So I have a question about any precautions that you guys normally take when you’re testing your pool water. I use the tailor 2006C test kit to do my testing. I don’t normally wear any type of glove when testing. Of course I do avoid getting any of the Chemicals on my hands and when I’m done I rinse them out in the sink by holding the test tube at about a 45° angle and let water run out the top to dilute the chemicals for about 3 to 5 seconds. Question is, should I be more concerned and wear some kind of hand protection?
I do use the speech to her as well and I dump out the magnetic pill into my hand after that and rinse it a bit more...
None of the Taylor test reagents in the K-2006C are hazardous. You can handle everything with bare hands.
