I'm getting ready to tear up my landscape in order to change my pool surround, remove rocks from the lawn, lay some drainage pipe, grade and add topsoil. Before I do that, there are a couple of things I'd like to address. Currently, the pool has not been open for a couple of years, and I'm about to get quotes for resurfacing and finding leaks. If you have any advice on these, please let me know:
1. I want to raise my pumps and filter by approximately 6" to 1', since they are next to the house, and I need to add soil there so I can pitch the grade away from the house. I haven't worked on pool PVC before (have done regular plumbing drains/vents). I'm thinking all I'll need to do is cut dig around the various pvc coming from and going to the pool, cut the pipes, add a coupling on either end, and a few inches of PVC between. I'll first need to drain the pool first, low enough so there's no water in the pipes, since I think the pumps are currently a little lower than the skimmers. Is there anything I should know before taking that on?
2. I'd really like to have someone come out and test all the lines to and from the pool, before I do my final landscaping, etc... Just so in the event that something needs to be dug up, it's not a disaster. I'm thinking, first I'll raise the pumps, (as per #1 above), then I'll hook up the pumps and have a pool person come and test things. Any other suggestions on that?
Thanks for any feedback--
