Power Outage
Sunnymosmile
151
Raleigh, NC
Hi TFP Peeps
I live in NC and we had a unseasonal snowfall today. Well of course, people think they can drive and someone crashed into a transformer about 30 minutes ago. The problem is, my pool is not winterized. The power company says the power will be restored in 4 hours. When do I need to start stressing and what, if anything, can I do to mitigate any damage? It’s currently 33° and it will be dropping to the high 20s.
proavia
1,677
Chandler AZ
Chances are it won't be an issue if the power is restore in 4 hours. Maybe cover any exposed pipe and components with a tarp - and put a work light (with incandescent bulb)under the cover to generate a bit of heat.
Reactions: Sunnymosmile
wireform
In The Industry
Aug 15, 2017
890
Spring Valley, NY
Four hours is a non issue. Turn off the power to the pool and cover the equipment pad with a good tarp to keep any wind off the system. Wait it out and then turn it back on at the earliest possible chance. Maybe a good time to think about the future of having a small portable generator hook up.
ajw22
13,143
Northern NJ
Get familiar with the ...
So if you would like to be able to go without automated freeze protection OR you would just like to have an extra layer of protection, then you can follow some of the suggestions listed below. The temperature ranges and time are using the thermal loss spreadsheet above which are fairly conservative freeze estimates (i.e. assumes 15 mph winds, full sky exposure with maximum radiation losses and ignores latent heat in filters and surrounding structures).
1. Air Temp 32F->25F->32F for <10 hours. Plumbing 1" and above is safe. Tarp or drain for smaller pipes.
2. Air Temp 32F->20F->32F for <10 hours. Plumbing 1.5" and above is safe. Tarp or drain for smaller pipes.
3. Air Temp 32F->15F->32F for <10 hours. Plumbing 2" and above is safe. Tarp or drain for smaller pipes.
4. Air Temp 32F->10F->32F for <10 hours. Plumbing 2.5" and above is safe. Tarp or drain for smaller pipes.
5. Air Temp 32F->0F->32F for <10 hours. Tarp equipment and use an incandescent light bulb underneath OR use heat tape available at your local hardware store.
6. Air Temp <0F. Drain all equipment and plumbing.
Reactions: wireform
