POWER OUT MEMORY SETTINGS HAYWARD 950 PUMP
MarkThomasAZ
20
Scottsdale, AZ
Hello - I have a Hayward 950 VSP Pump and the timing is setup on the digital display
to run every day. My question is this - If I want to not run the pump one night can I shut off
the disconnect to not run it. Will the pump lose its memory settings if I shut off the breaker.
Is there a better way to shut the pump off for one cycle?
mknauss
36,046
Laughlin, NV
Fiberglass
Pentair Intellichlor IC-40
If you are using the controls located on the pump, based on the owners guide, you push the Stop/Resume button. That places the pump in Service Mode and will not resume normal operations until pressed again.
MarkThomasAZ
20
Scottsdale, AZ
Sounds good. I do see that button and it flashes when it is in stop mode. I will use that.
Mark Thomas
Reactions: mknauss
