Poured concrete cantilever deck connected to bond beam
Bill O
19
Las Vegas
Hi
I'm in Las Vegas doing a pool renovation. I want to install poured concrete cantilever deck, but none of the installers isolate the deck from the bond beam, and some even install rebar into the top of the bond beam to lock them together.
Is this acceptable? Is it just a Vegas thing?
Thank you for you help!
Then absolutely not, there should be no bond between deck and bond beam.
maybe i could ask another question. i had a bond beam restoration done but the concrete was poured very unevenly. they said they are going to build up the top and the face of the beam to make it plumb, flat and even. i believe that they want to use type s mortar. some areas on the face look to need around 1.5 inches of buildup. would this work as a substrate for waterline tile? thank you again!!
