Still new to posting, but a long time following TFP. I have run into something interesting ... I was averaging FC usage between 1.5 and 2.5ppm's per day using Walmart Bleach (8.25%). They have had a good deal on Walmart Chlorinating Liquid (10%), so I have been using that the past 2 weeks (exp. dates are fine). After adding regularly as per PoolMath, I keep finding my FC higher than anticipated and I'm using less than .5ppm FC/day since using their chlorine. Have had a bit of rain and clouds, but mostly sunny and moderate swimmer usage. Here's my recent numbers and what I found out:
6/26
FC - 6.5
CC - 0
PH - 7.4
TA - 100
CH - 210
CYA -40
TEMP - 78
6/27
Added 1/2gal of Walmart Chlorinating Liquid at 8am
6/28
FC -9.5
CC - 0
PH - 7.4
Temp - 74
(Didn't test TA, CH, or CYA because they have been the same for the past several weeks)
My pool is still crystal clear (thanks to TFP!!!) ... It doesn't make sense using hardly any chlorine, BUT ... If I plug the 12.5% number in PoolMath as opposed to the 10%, it makes sense ... It doesn't effect me or my pool, but it COULD effect someone doing a SLAM (wasting $$$). Maybe a POSSIBLE heads up to someone doing a SLAM! ... So the label may be off!!! Here's pics of the bottle:
Don't know if I'm missing something, or possibly helping someone save $$$ down the road!!! ... As always, this is the ONLY place to reference or use to take control of your own pool ... Thanks loads
6/26
FC - 6.5
CC - 0
PH - 7.4
TA - 100
CH - 210
CYA -40
TEMP - 78
6/27
6/28
FC -9.5
CC - 0
PH - 7.4
Temp - 74
