Popup Pool Bubblers one stronger than the other
RMcGirr83
970
Tuscola, TX
Turned on the bubblers today and noticed one is definetly stronger than the other (shoots higher into the air). They are both plumbed on the same line with one actuator to activate them. Is there a way to remove these to check for a blockage in the bubbler or something? Do they simply screw in like eyeball returns?
ajw22
26,410
Northern NJ
Pentair Intellichlor IC-60
It is usually recommended when multiple water features are on one line to have a valve for each to balance flow.
What model bubbler do you have?
