Pool water is above skimmer line
TimRock
10
Tampa
Not sure if this is the correct category, but for the past few days my pool has been a little above the skimmer line. Is this ok? How can i get it back to normal (it was usually up to midway of the skimmer.
ajw22
18,144
Northern NJ
As long as pool water is not above the top of the skimmer I would let evaporation lower the water. That way you don’t lose any CYA or salt in draining.
Reactions: TimRock
DiverGirl1972
188
Delta, PA
As long as you dont have heavy rains in the short-term forecast, evaporation MAY get you back to normal in a week or less. You can also jump in and splash it up!
I recently went to add a half inch of water to my pool and fell asleep. Whoops. The water was at the top of the skimmer box. It took 6 days before the water was below the skimmer opening again.
You can use a cheap pump to lower the water level. While your skimming capabilities will be non-existent until the water recedes, otherwise, your pool will be ok. I just had to use the net more.
Reactions: TimRock
TimRock
10
Tampa
thanks for the replies. We did get a lot of rain last week (i'm in Tampa), but it hasn't rained in a few days so now, so i just wanted to make sure i was in good shape.
SBall
250
Nashville, TN
I keep our water level at the top of the skimmer opening, only about 3" of liner shows above the water line. The only drawback is that surface debris (leaves, grass) aren't sucked into the skimmer as efficiently, but I am ok with that.
