Pool Turned Green After SWG Boost
Salonso
7
Perris, CA
Hello, my pool was ok yesterday. The color was clear if not a little cloudy. I decided to turn my SWG to “boost” mode and woke up this morning with my pool water now a clear green.
This was the first time I turned on my SWG and boosted it btw, as this is a new pool. The walls of the pool don’t feel slimy. I checked my numbers today and my pH was 7.8 and FC was 1.8 (I have already added products to fix that).
I read that metals can cause this, so idk if it’s that or the pH level? I have a sacrificing anode in my skimmer, would that be the source if the cause IS metal??
mknauss
54,386
Laughlin, NV
Fiberglass
Pentair Intellichlor IC-40
Looks like iron. Put some paper towels in your skimmer. Do not block the water flow. See if they turn brown.
Reactions: Salonso
Salonso
7
Perris, CA
This was after probably not even 2 minutes of the paper towel being in there. Even my hand looks a little discolored.
mknauss
54,386
Laughlin, NV
Fiberglass
OK -- get some polyfill (pillow stuffing) as quick as you can. Get it in the skimmer. Run the pump and try to get as much of the iron out as possible. You really do not want it to stain the pool surface.
Reactions: Salonso
Salonso
7
Perris, CA
Thank you!! I will do this immediately, but I am wondering.. is there a filter that can do this also? Because I think I figured out the source.
The pool is a few feet away from a tree whose leaves fall in occasionally. I think they may be causing the problem?
I took down this Pool twice, and the second time after I drained the water I left the pool out for a few days, when I came back to thoroughly brush the liner the outline of where the leaves lay had turned a rusty brown. I just remembered this. Even my sister said something like “It rusted so quickly already??”
If this is the source, this will definitely be a reoccurring problem until I cut down the tree.
mknauss
54,386
Laughlin, NV
Fiberglass
Trees do not add iron. Your fill water does. Not much. But some.
The cartridge filter will catch some if that is what you have. But the polyfill is the best for a quick fix.
Reactions: Salonso
