Pool timer
BPool18
180
Cincinnati
Hi all,
Last year I had my pump running 24/7. Found out here that’s a waste.
I was going to go ahead and purchase a timer...and have an electrician install it shortly after opening.
Questions:
1) is there a specific timer that is recommended?
2) how long should it run for daily? Continuous or broken up?
3). For getting the pool up and running after opening (shocking etc), should it run continuous until clear/testing shows it’s good?
Mendy48
737
Midland, MI
I'm not sure there's a definitive answer for this. It really depends on your pool.
1) I run mine for 8-10 hours during the day, which I know is extensive. Others run theirs shorter.
2) Continuous (rests at night)
3) If you SLAM your pool, you should run your pump continuously until you're done with your SLAM.
ajw22
11,255
Northern NJ
Exactly which one depends on your pump voltage.
Depends on what you need done. You should run your pump for 24 hours after adding stabilizer or salt since those are difficult to dissolve and mix. Or if you needs a lot of filtering done.
