I have a Instamatic Pool Timer Model T104. I has the usual wiring. When the pool motor wouldn't turn on a few years ago I was given directions from the local pool Guy to test the timer. His instruction were to moved wires from terminals 2 & 4 to terminals 1 & 3 respectively to test if the motor would start,. It worked, the pump came on, we replaced the timer and all was well.
Now 3 years later, the pool pump won't start again so I want to repeat the test. My question is do I remove the wires from terminals 1 & 3 before connecting 2 &4 or just add them to the 1 & 3 wires, I would ask the pool guy but hes no longer around. And sadly I didn't note it when I got the instructions from him. Can anyone help me. Things are tight here and spending $50 or more for a callout just to see if the Pool Pump is shot it is not my first option.
