Pool teal and cloudy.
Jun 5, 2016
66
Whiting, Iowa
Hi, haven’t been on for quite some time but I haven’t had issues for quite some time. Opened my pool about 2 days ago and it was a mess from som e dust storms we had. I immediately began slamming and hand vacuuming. It started to turn blue and clear up but now it has just stalled for the last 7 days. I’ve kept my chlorine levels at about 25-30ppm any CYA is down around 10-15ppm from all the water adds, the reason o found it concerning is I’m somewhere in the ball park of 60 gallons of chlorine used. I haven’t had any combined chlorine for about 8 days. My TA and hardness are both high from my area but they’ve always been high. Just wondering if this is a filter issue? Taylor k-2005 test kit D4154044-CF00-4E7F-A578-D4CAC09B4CCB.jpeg
splashpad
0
2,885
SE Kansas
Is there a chance of metals from the water source? (or even the dust blown in) Can you post a full set of recent test results? I would take care using that high of FC amount with little CYA to buffer it, you can risk pool or equipment damage.
I see you have a sand filter, have you tried adding SMALL amounts of DE, to remove the finer particles?
Jun 5, 2016
66
Whiting, Iowa
We live in a river valley with high water table and farm ground. Our water is high in nitrate and ammonia. But like I said it’s always been hard and less than ideal water and I’ve never had an issue to this degree. I did change the sand out toward the end of last year, I’m hoping I didn’t Jack something up. I also got a new pump and removed my online chlorinator, now it seems I have way more water flow coming out of the return ports?
splashpad
0
2,885
SE Kansas
FC 33ppm
CC 0
CYA 15 ppm
TA 110
Calcium 350ppm
pH 8.9
If leave the pump off I will get fine dust/dirt settling on the bottom of the pool.
  • The PH result is 'invalid' at FC that high
  • I would add CYA to get to 30ppm
  • Let your FC come down before adding more (UV should burn it off quickly)
Do you have/use a skimmer sock? (something as simple as a hair net works great)
splashpad
0
2,885
SE Kansas
You have a lovely pool area, BTW!
... removed my online chlorinator ...
Just double checking, do you mean inline?
Do you have any staining in the pool? (on walls, stairs, floors, etc)
... I also got a new pump and removed my online chlorinator, now it seems I have way more water flow coming out of the return ports?
Is the pump the same size (power) as the one you replaced? Sometimes a pump can produce a stronger flow then a filter can handle, though I don't think that is the issue here :)
Can you take a picture looking straight down into the pool at your bottom stairs? And how deep is that?
Jun 5, 2016
66
Whiting, Iowa
Stairs are getting a yellowish tint, when I get home I’ll get you a picture. You can see the liner. And yes I did mean in-line, pump is same size. When I initially changed the sand I replaced the radials too, not sure if needed to put some sand in the bottom but the stand pipe wouldn’t come all the way up into the bottom of my multiport so I added an extension, could that be an issue?
splashpad
0
2,885
SE Kansas
Under the water line? Are there any pool stores that could test your water for metals? (the only result that is acceptable to use as a reference from pool store testing, metals are either present or not)
Did you happen to take a picture? If the connection isn't fully sealed, then the pool water would not get filtered properly
Jun 5, 2016
66
Whiting, Iowa
Here is a picture from the stairs… as you can see it’s a fine layer of “dust” now we have had some horrible dust storms here over the last 3 weeks which I’m partly blaming 39137AAC-8D6E-4B39-8AC0-B5356A9F7CBA.jpeg
splashpad
0
2,885
SE Kansas
Are you watching the pressure on your filter? You can wait to backwash until the pressure increases 25% over 'clean' pressure. Use the "free" dust to your advantage!
Also if you can acquire hairnets and polyfill (like what's in cheap pillows or blankets), they might do wonders to help clear your water as well.
I’ve been slamming for 2 weeks, I have had no CC for about a week now, FC is 35ppm
Please let the FC come down and check your CYA level 24hrs after it's all dissolved. This test should be done in bright indirect light conditions.
Jun 5, 2016
66
Whiting, Iowa
CYA is up to 30 ppm now, I took the multi port off the filter again. Sand level looks good, and as tight of a fit as im getting on the standpipe it’s just not feasible to be leaking back that way during normal filtration. Im thinking either the sand is just not filtering properly or what I’ve got is just too fine. Im going to try a flocking product, what is this poly fill? Like quilt batting im assuming? And do you just place it in the skimmer basket?
IceShadow
4,573
Milwaukee, WI
Pentair Intellichlor IC-60
Some questions:
- What sand did you put into the filter to replace it last year?
- I see you have the robot but are you scrubbing in places the robot may not reach?
- How often are you testing and bring it back?
Note that if your CYA is 30ppm your SLAM level is 12 per the FC/CYA Levels. No need to go over - it's wasteful of the chlorine and as others have said could be harmful to your liner and equipment.
splashpad
0
2,885
SE Kansas
That's good!
You did use pool filter sand to replace? Sand filters will clear a pool that is balanced chemically, but need a little assistance from us to do so "quickly" :)
This is definitely not recommended on TFP!
Yes that is it and as long as you have it in a hairnet or bag (to prevent it from being sucked into the pump) that is where it goes.
