I just had a technician replace the pool pump timer as it wasn’t working and I had to manually turn on the sweep and pump.
However now he has replaced the pump timer that now works well and turns on automatically, the pool sweep does not turn on with the timer OR manually when the pump is on. The switch does nothing.
I can’t for the life of me find someone who can come out and help me as I guess it’s too small a job and the market is crazy so want to see if I can diagnose / fix myself.
Pics attached of the timer as is in case it’s something more obvious. Even if I can manually turn on the sweep it would help a lot as the pool is clear and looks good but I have a ton of dirt sitting at the bottom of my pool so can’t use it yet.
