Pool supports
rockgod
7
Chicago/il
Hi All,
Hope this is in the right spot.
Going on 4 years of our 15'x30' oval pool and I'm noticing that one of the supports looks like it's leaning outward and I'm wondering if it's normal or something to really be concerned about. I'm not 100% that it wasn't always like this... never noticed before. In worried that it'll keep getting worse and collapse. Thx...20210318_183752.jpg
kellyfair
4,235
Tampa, FL
Intex Krystal Clear
It kind of looks like it wasn’t installed straight.
Casey
11,919
SW PA
Fiberglass
Jandy Aquapure 1400
Cant really tell with the cover on it and rocks around the base.
rockgod
7
Chicago/il
Casey,
Maybe this will help. There are 4 posts on the sides and then it starts to curve. The one i'm concerned about is the closest in the original pic. It is way off level, as is the one next to it (second from the curve). The next is perfectly level. I'm assuming all posts should be level for max support.
Casey
11,919
SW PA
Fiberglass
Jandy Aquapure 1400
I can see that it's out from the first pic but I'd like to see the top of the rail. If the wall is sitting in both top n bottom tracks. If it is, it should be fine but if its not... that's a different story.
Teald024
Have you noticed any high spots on the pool floor near those two supports?
I'd like to see a shot looking down the top rail along the side, a bit above. It's gonna be hard with the cover still on. Do you have any pics from the last 2 years?
