pool store testing
jmikeb
298
stillwater oklahoma
a good friend of mine sent my a pic of his pool store water test.
fc .50
cc 0
ph 7.4
TA 22
ch 310
cya 50
is it possible to have a ta of 22 and a ph of 7.4 ??
he has an IG plaster 15000 g pool
ajw22
22,134
Northern NJ
Pentair Intellichlor IC-60
fc .50
cc 0
ph 7.4
TA 22
ch 310
cya 50
Not likely. All pool store tests are questionable.
If his pH is in the 7's He should not touch his TA. And he should get his FC up.
Tell him to get his own test kit. Did he buy any chemicals at the pool store?
Texas Splash
Or ...... if you and your friend live near each other, do him/her a favor and run a quick set of tests with your K-2006. Compare results so you can see the difference.
funny... he bought the 2006c and the speed stir! i think he’s overwhelmed
Oh, I see you just posted that. Well then, he needs to stop going to the pool store and rely on his own testing. Gotta cut that cord.
ajw22
22,134
Northern NJ
Tell him to check in here and we wil help him. Lots of folks go through the process and get the hang of it.
jmikeb
298
stillwater oklahoma
i think he bought a bunch of stuff.. i wish he did live close, i’d slap him about now
Donldson
4,620
NW Ohio
It's probably Adjusted TA, a lot of pool stores use that for some reason. What reason? Ask a dozen pool stores and get a dozen different answers.
Still doesn't mean it's accurate, just that the actual TA reading probably registered higher than that.
JamesW
22,038
To get the adjusted alkalinity, subtract the cyanurate alkalinity from the total alkalinity.
The cyanurate alkalinity is a percentage of the CYA based on the pH.
pH......%CYA to subtract from TA.
7.0.....0.22CYA.
7.2.....0.26CYA.
7.4.....0.30CYA.
7.6.....0.33CYA.
7.8.....0.35CYA.
8.0.....0.36CYA.
50(0.30) = 15.
15 + 22 = 37 actual TA.
In any case, just encourage them to do their own testing and ignore adjusted TA.
The people doing adjusted TA probably don't have any idea what it means.
Have them raise the TA and pH enough to get the CSI to at least -0.3.
If they raise the TA to 60 or 70, the pH will rise to 7.8 within a few days and then they will be in good shape.
Reactions: jmikeb
