Pool Store Comparison
melsteph
54
East Texas
AHHHHH!!!! I am still monitoring CYA and ran out of the reagant. Thought I would test everything else, take sample to pool store to compare my results, AND let them test CYA until my reagant arrives (or buy there).
My results with new Taylor K-2006 are on left. They used sticks and a Taylor machine (DPS)maybe.
FC ~ 12 /5
pH ~ 7.8/6.8
TA ~ 150/40
CH ~ 200/400
CYA ~ last reading was 120 (dilution test)
There system doesn't even test CYA so that was no help. Don't carry it in the store either!! Besides my frustration with the testing itself, WHY ARE RESULTS SO DIFFERENT???? (CYA reagent will be delivered Thurday if I don't find it sooner!)
I just want to do everything correct for best pool care!
Melissa
RMcGirr83
929
Tuscola, TX
We're in the same boat. My results aren't as different as yours though.
jblizzle
43,238
You should know the answer as to why the test results are so different:
1. Test sticks are garbage
2. Pool store testing should not be trusted.
Reactions: MyAZPool
Donldson
4,585
NW Ohio
Huh. I guess that explains why "we don't trust pool store testing and recommend you do your own testing with a reliable test kit" is one of our most common phrases.
:sneaky:
melsteph
54
East Texas
I KNOW not to trust them but I thought their test MIGHT confirm I'm doing this correctly. SO what measures do I use to know my results are accurate? I am testing twice a day now to monitor (myself mostly).
Melissa
melsteph
54
East Texas
:sneaky:
I know that - but if I want to check myself for accuracy just assume I am doing it correctly? That's what I wanted - and the CYA.
Oly
1,656
Fresno, CA
Follow the testing procedures from your K-2006 and you will be doing it correctly. Practice makes perfect.
Also follow the directions on the FC test for using a 10ml water sample but use only one scoop of the powder. Each drop equals 0.5ppm FC.
Reactions: melsteph
