Pool/Spa Automation controller?
outatime
Active member
Apr 6, 2015
32
Davenport
Hi Guys
Need some advice please, I have a friend who's in ground pool and spa currently uses a Hayward Pro Logic controller but its not in good shape and needs replacing. I am considering a Hayward Omni Logic system as I am thinking the wiring won't be that different and also the internet option sounds good although I understand it needs Ethernet cable to run to the router but that's not an issue. I have installed a Hayward On-command myself and the Hayward controllers seem to be similar in setup menu's and what not.
Anyone use a Omni system before? Will it do the job? I am looking to control a Hayward pool heater, pump, 3 jandy valves and add a salt system to it at some time also.
Appreciate any advice
Thank you
Stuart
