Pool Skimmer Question
JTAG
78
Babcock Ranch Florida
Why is there 2 holes in the bottom of my skimmer under the skimmer basket? One hole obviously goes back to the pump. Im asking because when I felt in the other hole there was a lot of rock and sand in it like it was plugged. I used suction to clear that hole and it is open now. Im worried that there was suppose to be a plug in that second hole and now I sucked it out. Found nothing but stones in pump basket. The pool is a fairly new build and we just moved in. Thanks for the help
Jimrahbe
19,832
Bedford, TX
J,
In the old days, most pools had their main drain connected to the 2nd hole. Normally the hole next to the water went to the main drain and the other hole when back to the pump at the equipment pad. Most newer pools have both the main drain and the skimmer going back to the equipment pad.
The "extra" hole should be plugged from either the bottom or the top.
It can't be open, as the water would just drain out of the skimmer..
Jimrahbe
19,832
Bedford, TX
J,
The plugs are screwed in, so I doubt you sucked it out.. It is down about a foot...
I am assuming that your main drain is plumbed back to your equipment pad..
JTAG
78
Before I attempted to suck it out I couldn't put my finger into the hole at all. After I could stick my finger all the way down as far as it would go.. If I did suck out a plug or screen what would happen worse case scenario.
Jimrahbe
19,832
Bedford, TX
J,
Worst case, the pool will drain down to just below the skimmer. An open pipe into the ground, will just let water pass through it and into the ground. Depending on the type of dirt you have this could take hours..
Is this a new pool or a very old pool? How many pipes come up and then go into your pump?
Show us a pic of your equipment pad..
Jimrahbe
19,832
Bedford, TX
J,
Thanks for the pic.. It is pretty clear that your main drain is plumbed back to your pad..
Do you by chance have a eyeball about a foot below your skimmer? I have those, and they are called equalizer ports.. In theory, if the water drops below the skimmer mouth, they will provide water to the pump to keep it from running dry.
If you don't have an equalizer port, then the second hole is most likely plugged at the bottom of the skimmer.
PoolGate
5,076
Damascus, MD
Jandy Aquapure 1400
I have the second hole too. It's plugged at the factory you did not open it up. Mine is also filled with stone and rock from the pool build.
superuser
Active member
Nov 16, 2020
40
Spring, TX
I've got the same setup here, just moved in a month ago and it had me scratching my head. Floor drains run back to the pad, but instead of plugging the second skimmer ports with a cap they're filled with sand and gravel. I do not have equalizer ports.
PoolGate
5,076
Damascus, MD
Jandy Aquapure 1400
They aren't filled on purpose; it's just sloppy builders!
