Hello,
Long time lurker, first time poster and also a new pool owner trying to get it up and running for the first time.
I had a pool company come in and do some new valve work, as well as install a new variable speed pump. I got all new Praher ball valves for my pool and spa returns, my skimmer, main drain and spa drain lines, and also on either side of the pump. The only problem that arose was the pipework tying all the suction lines together was not glued well, so there is a (seemingly) small air leak. When the system is off, that drips water and I can hear it hissing. The company is coming back to fix that joint later.
In my excitement, after filling the pool halfway, I draw from the main drain to prime the pump and noticed that while the return jets eject water, it was quite weak and also very intermittent. I figured the main drain was probably not generating enough suction and the water level is too low so I gave up and waited. In the meantime, I installed some new 1" eyeballs to help lessen the pressure at the filter.
The pool is finally filled up (halfway up the skimmer door) and I go to turn on the system. The pump seems to prime well via the skimmer and main drain line and I can feel water moving through the pipes through the pump, to the filter and at least from the filter to the heater. However, at the return jets for the pool, it still takes some time for water to come out and when it does, it seems fairly weak. The water comes out intermittently as well in a smooth column for about 30 seconds. From what I can tell, the in-ground cleaning system seems to work alright -- I can see debris being moved and I believe they are tied to the return system as I don't see any additional piping for it from the pool room. The return jets are not bubbling, just weak. The spa jets appear to work fine (which is weird to me because the return line is one pipe that splits off into the pool return and the spa return via valves).
I've tried the multi-port in filter and recirculate. The results seem to be the same.
I've been trying to figure this out and determine what's actually wrong with the system. Here are my thoughts and I appreciate if you check my logic:
1) The small leak just after the drain ball valves is actually the one causing all this problem even though it is extremely minor. However, I don't see air bubbles in the returns when they work... maybe the leak is just so small that it isn't negatively affecting the pump, but still causing the returns to not perform well? A lot of what I've been reading from here and on YouTube seem to suggest that suction side leak (which I think this is) is the main cause for weak pool returns.
2) There may be a clog in the line to the return jets, although I can't really imagine how that could be if the jets work fine for about 30 seconds at a time.
3) There is a leak at the pressure side, but I don't really understand how that could be as well if water comes through intermittently only. I am not losing any water in the pool from what I can see, and it would be impossible for me to notice any wet patches as the deck is all concrete.
4) The spa jets work fine because the returns there are all high-pressure jets, whereas the pool has big eyeballs. It still doesn't answer why the spa returns work okay but the pool returns are so intermittent and weak.
I'm at my wits end and trying to just understand how all of this works. How can it be that the spa jets work but pool jets don't?!
Thank you all kindly. This community is awesome!
