I opened my pool this morning, added 1lb of shock, balanced my water, ran the filter for the day. (last season I needed like 1/2 lb of shock when I opened).
I have an 8,500 gallon oval, above ground pool, and a hayward DE filter with a 1hp pump...
This evening I tested the water, 0 chlorine, added another lb of shock, 0 chlorine, added 2 more, 0 chlorine, 3 more...........I kept going till I had 9lbs of power shock [Calcium Hypochlorite] in the pool (diluted in warm water first). At one point I saw 3ppm of TOTAL chlorine, but always 0 Free chlorine.
I did notice some tree debris in the bottom of the pool, the robot vac has been going all day but isn't doing a great job so I'm going to manually vacuum.
Anyhow is this normal? I read somewhere shock will attack all organic material first, so did I make a mistake by trying to shock before having every spec of organic material out of the pool first? I'm so annoyed I wasted 9lbs of shock already. The pool is not green at all, walls not slimy, and the pool was not too bad when I took off the cover, ofc now it looks less clear with all the shock I added.
Should I vacuum like mad and keep shocking, I feel like draining the water when its not even a little green is a waste, but then again so is all the shock I just dumped in.
