pool on top of asphalt driveway
imaddicted2u
2
Nova Scotia
My brother wants to install a 12X22 foot by 52inch deep above ground pool on top of an unused portion of his asphalt driveway. The manual says not to install it over asphalt. Anyone know the reason why? Could it be the asphalt can't properly support the 58,000 pound weight of the pool? The driveway is not quite level so there will be a layer of sand over the asphalt. Should he do it? Any suggestions around base preparation/installation would be appreciated.
jblizzle
43,255
:wave: Welcome to TFP!!!
The only reasons I can think of for not putting a pool on asphalt would be
1. A possible interaction between the vinyl and the oils in the asphalt
2. The legs may sink into the asphalt as it is fairly soft when hot
Mats and/or sand could avoid issue #1, and perhaps some thin pavers or plywood could help with #2?
Certainly need to ensure the structure is leveled to with 1" all the way around.
imaddicted2u
2
Nova Scotia
Thanks for the speedy reply. He said it's out of level by 3/4". He plans to put 12x12" concrete patio blocks under the legs. Level them up and fill in with sand. Then install the pool. Sound reasonable?
Bama Rambler
23,525
It'll take a pretty good layer of sand to isolate the vinyl liner from the oils. I'd put down a big tarp then the sand and then the pool on top of that.
