Pool Math Target pH
ozviolinist
5
Auburn, AL
Hi all,
Just wondering why the target pH level in the Pool Match app is set at 7.4, yet the 'ideal' pH level is 7.6-7.8. Is there a way to fix the target pH number in the app so I don't keep having to change it everytime I test? Or should I be aiming for 7.4? I'm holding steady at 7.5-7.6 currently.
TIA
mknauss
30,872
Laughlin, NV
If you are holding steady at 7.5 - 7.6, no reason to adjust it. Remember, the levels are ranges, not specific numbers.
You should be able to change the target level and it hold for awhile. We do not like to make that permanent as it can derail some newer users.
