Pool Math App not showing values.
Fire
66
Toronto Ontario
Hey- not sure if this is the correct place to post this, but my pool math app does not show current values. All my logs are recorded but on the overview it's not showing current levels. I upgraded to Pro, but it still doesn't show my current levels on the overview page. Any suggestions to fix this?
bmoreswim
Platinum Supporter
5,866
Central MD
It may not be accurate due to an issue (which Lee will address), but I closed my app (iOS) and when I reopened the summary/overview was then correct.
Leebo
Admin
9,518
Eastern Ohio
PoolMath is not going to update your test results based on chemical additions, there’s to many variables to attempt to account for that we’d likely give false results if we tried that. Looking at your logs (thanks for sharing) it shows you’ve only entered one set of test results. Test again and record your second set of test results for the overview to update.
Reactions: afbatts
Fire
66
Toronto Ontario
Thanks! I just updated it. Working great!
  • Love
Reactions: Leebo
