Pool Math App in IOS
csconner
103
Nashville, Tn
Fiberglass
Pentair Intellichlor IC-20
Hello All,
Relatively new user, just downloaded, installed and subscribed to Pool Math App on IOS.
Problem - Pool Math App not saving input data.
I sign into App with my TFP ID & PASSWORD
I created a new pool
I used my Taylor kit, tested water, entered data, but noting was saved.
Note: My pool name and other settings plus first log I created (prior to subscribing) all save into app, but will not save FC, Salt, CYA, etc...
Help Please.
Thank you
Craig
Jul 16, 2020
15
Augusta, GA
Hello All,
Help Please.
Thank you
Craig
Did you create a new log by tapping "add new log" and "add test results"? Or are you adding them on the dashboard? The latter does not save the results, but gives you advice for getting to your target.
Sounds like you just need to "add test results".
Reactions: mknauss
csconner
103
Nashville, Tn
Fiberglass
Nope I did not... so, seems I need a basic course on how to use the Pool Math App. Doh!!!
I just clicked on the FC, PH, CYA part of the home screen and added in my numbers.. and they weren't saved... :-(
I see now the +New Log, Add note, track $, Perform Maint, Add Chem's and LOG TEST RESULTS...
Ok, that helps... I'll have to rerun my tests and enter them correctly...
Thank you
Jul 16, 2020
15
Augusta, GA
Thank you
I did the exact same thing for a couple days and was frustrated with re-inputting the data. Then it clicked! "Doh!", indeed!
csconner
103
Nashville, Tn
Fiberglass
Reactions: mknauss
Leebo
Admin
11,017
Eastern Ohio
As a very small tease, we’re slowly working to make things more user friendly. It’s a very slow process this year, but we’re looking to help users avoid this same error……
csconner
103
Nashville, Tn
Fiberglass
Update
As cubaboymatt1316 shared the app works correctly!
I'm able to create a new log add my #'s and save them and they show up in the dashboard.
Thanks
Reactions: mknauss and Leebo
