Incidentally do you recommend the pH tester you’re using? The rainbow test is infuriating.
Yes, I am very happy with my Apera pH60. Just make sure to keep it calibrated (when it was new, I was quite OCD about that, but I settled now on a monthly calibration). Make sure to work "clean", i.e. rinse the sensor a couple of times with pool water before making the measurement. I also always store it in storage solution, I found that like that the readings are more reproduceable - especially the time it takes until I can take a reproduceable reading. And when rinsing the sensor with distilled water and drying it with a paper towel before putting into storage solution, you can actually reuse the storage solution. I always keep the provided cap filled with storage storage solution and use my CCL pH test-tube for my water testing.
Play a little with the waiting time before taking the reading. If you just want to replace the colour based test with the same accuracy (about 0.1-0.2), then you can take the reading after about 30sec.
If you want to make use of the two digits of the PH60 (compared to the 1 digit of the pH20), then you should wait a couple of minutes - probably not required for daily pool maintenance, but nice to have when trying to "understand" your pool (especially when being at home due to lockdown...). With the pH60, I actually see the pH fluctuations over the course of the day when chlorine is being created by my SWG and when it's being used by organics and UV. And how over the whole cycle (by measuring pH always at the same time), the SWG-chlorination is actually pH-neutral (as long as your TA is low enough to minimize pH-drift by CO
2 outgassing).
In the end, I decided to get the pH60 (and not the pH20), because the sensor head can be replaced. I like the idea of being able to fix something rather than throwing the whole thing out (including its packaging).
