Pool lights not working
Moe 103
12
New Jersey
Pentair Intellichlor IC-60
I have two in-pool lights that I can’t turn on from my Pentair app. I have the IntelliCenter and when I go to the light section and turn on all on, nothing happens.
I reset the GFI with no change. Am I missing the lights as there is no lights in the menu? How does the IntelliCenter know where my lights are? Should there be a circuit (aux) labeled lights?
Thank you
ajw22
24,880
Northern NJ
Did you create an Aux circuit for the light?
What did you set for the Circuit Function for the Aux circuit the lights ia connected to?
Jimrahbe
21,218
Bedford, TX
Moe,
Your lights should be listed on the light page..
If nothing is listed, nothing will turn on.
Who programmed your IntelliCenter?
Show us a screenshot showing all your Circuits..
Moe 103
12
New Jersey
I did not create an AUX circuit for the lights. Do I need to know which one the lights are hooked up to?
ajw22
24,880
Northern NJ
Yes, you need to tell the IntelliCenter which Aux relay controls the light.
Moe 103
12
New Jersey
So there should be a wire from the circuit breaker that controls the light that connects to an AUX, because I don’t see one. There is a wire into the breaker labeled lights but nothing coming out of it.
Moe 103
12
New Jersey
The bottom breaker is for the lights but I don’t see anything connecting it to an AUX.
ajw22
24,880
Northern NJ
The light CB power runs to the GFCI outlet LINE side. The GFCI LOAD side connects to the second Aux relay from the left LINE1. Your light comes up and connect to the relay LOAD2 screw.
Reactions: Moe 103
Moe 103
12
New Jersey
Thank you everyone for your help. The lights are on AUX 1. I set AUX 1 in circuits to lights and they work. Yay.
Reactions: Jimrahbe
