Not a fan of messing with things I don't know when it involves electricity (and water..), so had my pool guy replace our burnt out pool light. Changed the bulb, and as the subject says, it stays on for about 5 minutes, then turns off (presumably to cool down) for about 5 minutes, then repeats this cycle.
Light is a Pentair Sunlite LTC 05605 -- 120v, 250w.
Instead of calling out an electrician to find out where the problem is, I was hoping I could just replace this with a cooler LED bulb to maybe get around the issue -- but it doesn't seem like anything is compatible with this.
What's my best option here? Should I be looking to replace the entire light with something more modern/LED? Would I want to call out an electrician to convert it from 120v -> 12v?
Thanks!
Thanks!
