Pool Light Repair
George Whitzel
159
San jose, california
Does anyone have experience replacing the bulbs in a pool light. Measured the voltages to light and found good. Pool light says there are 8 bulbs that should be replaced together and also a cover gasket that needs replaced. I am wondering if opening the pool light to replace the bulbs is difficult and are there any precautions I should be aware of. I have removed the light in the past to clean in the niche.
Arizonarob
3,014
Chandler Arizona
George, what brand/type of pool light is it? Can you post up some pictures of it?
Most pool lights will need the gasket replaced once you open it up.
George Whitzel
159
I put light back in pool without taking a picture of it but I did take pictures of the labels on it which is why I think the light is a Jandy, The label says to use 8 replacment bulbs with a Jandy P/N of RO399600. Also says to replace gasket with P/N R0399800.
