Hi,
I replaced my 120v pentair pool light today. It all went pretty smoothly, and the light is operational now. This is a 'new to me' pool that came with the house, so I don't know the history.
I have not lowered the water, chipping out the old epoxy sealing the conduit sure sucked!
However the bonding wire is causing me some grief.
- Just before I finished up, I gave the bonding wire in the back of the niche a very light tug to make sure it was still secure. Of course, the striped part of the wire broke off.
- So I stripped it and cleaned off the sealant over the bonding terminal.
- I went to screw the bonding screw in to re secure the wire, and it broke half of the terminal off. (longitudinally, from top to base)
- There's now no way to secure that bonding wire that I can think of.
- I've been through some great threads here of people who had similar issues, including some feedback from pool companies about whether that bonding wire is even needed. Because the pool was installed in 96, I'm pretty keen to replace everything with how it was, as I'm sure it was inspected and to code then.
I'm figuring I have two options
- Because half of the lug/post is still there. I'm wondering if I can somehow clamp the wire to it.
- I could also in a repair ring, this may also make the light more secure as it really just feels like it would be hanging by the pilot screw. The only issue with this, is I do not have a lot of bonding wire to play with, so I would need to extend it to reach the bonding/grounding lug since it would not be up front. Is it acceptable to do that I wonder? Pool Light Adapter Repair Ring
The other gotcha, is that the pilot screw does not appear to be long enough to secure the new light into the niche. Is there an extra long version of the pilot screw that you can buy?
I've looked online but have not had any luck finding one. Maybe the best bet is to just head to Lowes and find a matching longer SS one.
Any thoughts would be much appreciated!
This is pretty close to the niche that we have.
