pool light gasket
Belluca
Active member
Jun 5, 2016
44
Matawan nj
My light is no longer working. I'm thinking of replacing the bulb myself since it looks easy enough to do. i understand that i'll most likely have to replace the gasket as well once i open the casing. Is there a way to find out the correct size gasket without taking it out of the pool? I'm trying to save myself the extra step of having to remove it , replace it and then remove it all again when i get the bulb and gasket. It's a sylvan pool but on their website they had multiple options.
Also , does anyone have a bulb recommendation? The plain white LED bulbs i've seen are priced around $50-$60 and the changing color LEDs are only $80-$90 so i thought I'd get one of those b/c they look fun.
Thank you
1poolman1
In The Industry
Jul 14, 2014
2,691
Sacramento
Since Anthony/Sylvan pools had parts made for them, and they have been out of business for decades, it would still be good to see a picture. It could just be a re-named light.
You may need to replace the whole light, which, given the age of the light, is really your best and safest option. Be sure there is a GFCI in the light circuit.
Belluca
Active member
Jun 5, 2016
44
Matawan nj
ok thanks
Belluca
Active member
Jun 5, 2016
44
Matawan nj
So in order to ee what type of light i have i'll have to remove the fixture. Is it ok to leave the fixture out of the pool for a day or two until i get the new gasket?
Belluca
Active member
Jun 5, 2016
44
Matawan nj
finally got to take the light out. The only markings on it say swimquip 5055-11. Searching online i can only find replacements for 5057, I guess bc my model is so old. I orderd one and hoping that it fits. Thanks
