Pool Level?
Dsav99
2
Pennsylvania
Hi. So we've set up our 15x48 Intex pool and were very diligent in leveling the ground. Once the pool was set up we went around with both a line level and an board with a regular level on top to confirm before filling and we were all set. Now that the pool is filled the water level is deeper on one side, about 2". When we go around with our board and level again, the pool top is still showing to be very level, but you can see the difference that clearly something is off. What could make the water level be off when it still appears to be level based on the top ring? Thanks!
Dsav99
2
Pennsylvania
Thanks Yippee and Croket!
If the water level is off but the legs and top rim aren't does it make it just as unstable? I'm guessing so....we’ll prb have to drain and start again.
crokett
656
Hillsborough, NC
I don't think so, unless its way out whack and/or the walls are not plumb. if the walls are plumb and the top is level but the ground inside is uneven it should be ok, at least through the season. if the walls are leaning, then you have a problem.
