Hey guys, new member who just found this site!
I bought house that has a pool and drained it so I can start from scratch. It is an in ground kidney shaped 15,000 gallon pool. It has fiberglass walls with a seam every 10 feet and a concrete floor. The wall paint was flaking really bad and the caulk in the seams was deteriorating. I scraped out the old caulk and recaulked with tremco Vulcan 116. After 3 days we just had a heavy downpour and I have ground water leaking into my pool in a few spots still.
my question is how big of a deal is this? I assume if I fill my pool it will leak at these same spots. I have power washed it and plan to prime and paint the walls using
Kelly Technical Coating 216-GL Olympic Gunzite Gunzite Epoxy Primer followed by
Kelley Technical 392GL Olympic Zeron One Coat Epoxy Pool Coating
my next question is will this primer and paint fix the leaks?
