Hi all
First time pool owner and someone struggling to fix an issue that seems to never end. Also worried I am being taken advantage of by contractors due to my lack of knowledge. A quick background
1) Have a large underground pool and attached spa. Saw that when pump was running the pool level would drop to skimmer line so immediately knew there was an issue, likely a leak.
2) Got a leak detector out who tested and told me I have small leaks in the pool light and skimmers, so got these fixed.
3) This did not fix the issue and leak prevailed at the same rate.
4) Things that could not be tested were:
a) the sheer descent (it is plumed into the main plumbing so cannot be taken out of the system to test, not can it be pressure tested without drilling through my concrete deck)
b) the spa spillover into pool - they checked and saw no obvious leak nor heard anything here but this could still be an issue
5) I have had tests done running pool without spa and this seemed to find that the issue was the spa given pool didn't leak, but water pressure of sheer descent was very low - one guy told me this could be a filter issue and pool needs to be backwashed properly. I read online how to backwash and did this which solves the pressure issue but only for 30 mins and it starts to decrease again to a near stop - could this signify an issue and leak somewhere or separate issue?
So my questions are:
- If everything else was good, does it have to be the sheer descent? Will I have to drill into the decking to cut the pipe and pressure test/see whats under there? I essentially just want to take this out of the entire system now as its more trouble than its worth!
- Could there be another issue that would cause water level to drop?
- Is there anything I need to do to my filter that could cause this?
Please help! I am keen to try and fix it as much myself but understand when a professional is needed. Getting the leaks fixed and then follow up work has cost me a pretty penny so far and I am left with a pool that when the pump is run for 8 hours will leak from half way up skimmer to bottom!
Thanks
Thanks
