Pool leak
cwb
1
Redding California
Can an inground pool loss water around the faceplate of the skimmer. I have been losing water in my fiberglass pool. It has gone down 3/4 the way down on the faceplate and stopped the leak. There's still water in the skimmer, so is the problem the gasket on the faceplate
ajw22
40,050
Northern NJ
Pentair Intellichlor IC-60
Welcome to TFP.
You need to squirt some food coloring around the skimmer frame and see if you see it being sucked into the sides.
setsailsoon
4,797
Palm City/FL
CircuPool RJ-30 Plus
I've used Allen's technique several times. Very easy to do and very obvious when you have a leak. May help if you get in the pool let it get very calm and use a diving mask. All it takes is a couple drops a few inches from the suspected leak point.
I hope this is helpful.
Chris
