Hi everyone. About a month ago my pool heater stopped heating the pool. It still runs but even leaving it on for hours won't heat the spa. Are there any troubleshooting steps you recommend to narrow down the issue?
I don't see any error codes. The panel just displays the temperature settings. It sounds like the compressor is still kicking on. Ambient temp was around 70 today but warmer the other times I tried to use it recently. I just replaced my pool filter, pressure is around 17 for pool 22 for spa. Return water is cold but flow is normal.
Thanks for the recommendation, sorry it took awhile to get back to you. The AC company I bought my new units from a couple years back took a look and a capacitor was bad. They fixed it up and it's good to go again. Thanks!
